The Kingston Data Centre DC1000B is a high-performance M.2 (2280) NVMe PCIe SSD using the latest Gen 3.0 x 4 PCIe interface with 64-layer 3D TLC NAND. This is ideally suited for use in high-volume rack-mount servers as an internal boot drive(s) as well as for use in purpose-built systems where a high-performance M.2 SSD is needed. It supports maximize drive bays in which boot drives internally frees up front loading drive bays for additional data storage.
Optimized Server Boot Drive On-board (PLP) power loss protection Application optimized capacities (240GB & 480GB) Self-Encrypting Drive (SED) with AES-XTS 256bit
- Kingston Data Center DC1000B - SSD - 480 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 480 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- 3D triple-level cell (TLC)
- Form Factor
- M.2 2280
- Interface
- NVM Express (NVMe), Power Loss Protection (PLP), S.M.A.R.T.
- 22 mm x 80 mm x 3.8 mm
- 8 g
- 5-year warranty
- Capacity
- 480 GB
- 256-bit AES
- Form Factor
- M.2 2280
- Interface
- 22 mm
- 80 mm
- 3.8 mm
- 8 g
Performance
- Drive Writes Per Day (DWPD)
- 0.5
- SSD Endurance
- 475 TB
- Internal Data Rate
- 3200 MBps (read) / 565 MBps (write)
- 4KB Random Read
- 205000 IOPS
- 4KB Random Write
- 20000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
- Compatible Bay
- M.2 2280
- Power Consumption
- 1.9 Watt (idle) , 1.81 Watt (max read) , 5.47 Watt (max write) , 1.74 Watt (average read) , 4.88 Watt (average write)
- Limited warranty - 5 years , Technical support
- 0 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
