Kingston 32GB SDHC UHS-I Speed Class 3 Flash Card
Quicklinx: 98TXWS00 Mfr#: SDA3/32GB
Move to faster performance with Kingston's SDHC/SDXC UHS-I U3 Flash card. With speeds of 90MB/s read and 80MB/s write, it reads up to 9x faster and writes up to 8x faster than standard Class 10 SD cards. It meets the SD Association's latest specification release, UHS-I U3 (Ultra High-Speed Bus, Speed Class 3), which guarantees performance of at least 30MB/s and enough bandwidth to record and playback 4K2K video without interruption.
Users can capture cinema-quality Full HD (1080p), Ultra HD (2160p), 3D and 4K2K videos on high-performance cameras such as Digital Single Lens Reflex (D-SLR), Digital Single Lens Mirrorless (D-SLM), camcorders and video cameras. It's ideal for television recordings as well as live broadcasts, plus it lets you edit files faster and provides faster upload times, especially when using USB 3.0 card readers. Its higher sustained write speeds ensure video integrity by reducing stutter and allow photographers to shoot in continuous burst mode.
Kingston - flash memory card - 32 GB - SDHC UHS-I
Flash memory card
SDHC UHS-I Memory Card
Storage Capacity
32 GB
Speed Rating
UHS Class 3
Supply Voltage
3.3 V
Flash memory card
Storage Capacity
32 GB
Speed Class
UHS Class 3
Read Rate
Up to 90 MB/s
Write Rate
Up to 80 MB/s
Supply Voltage
3.3 V
Write protection switch
ISO 9001:2008
Limited warranty - lifetime
24 mm
32 mm
2.1 mm
-25 °C
85 °C
