Kingston 32GB DTVP30AV/ 256bit AES Encrypted USB 3.0 + ESET AV
Quicklinx: 9B0WWS00 Mfr#: DTVP30AV/32GB
Kingston's DataTraveler Vault Privacy 3.0 (DTVP 3.0) USB flash drive provides affordable business-grade security with 256-bit AES hardware-based encryption using XTS block cipher mode, which offers stronger protection than CBC and ECB modes. It protects 100 per cent of stored data and enforces complex password protection with minimum characteristics to prevent unauthorized access. For additional peace of mind, the drive locks down and reformats after 10 intrusion attempts. It also features a read-only access mode to avoid potential malware risks.
Companies can add DTVP 3.0 to their standards list with confidence since its industry-leading NAND and controller design allow for NAND to be interchanged without prequalification and certification of security features. Plus, they no longer have to compromise transfer speeds for safety, due to DTVP 3.0's SuperSpeed USB3.0 technology and backwards compatibility with USB 2.0.
Kingston DataTraveler Vault Privacy 3.0 Anti-Virus - USB flash drive - 32 GB - TAA Compliant
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash
Software Included
ESET NOD32 Antivirus
Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows XP SP3, Apple MacOS X 10.6.x or later, Microsoft Windows 7 SP1, Windows 8
TAA Compliant
5-year warranty
USB flash drive
Storage Capacity
32 GB
Hardware Encryption
256-bit AES
Read Rate
Up to 250 MB/s
Write Rate
Up to 40 MB/s
Interface Type
USB 3.0
NAND Flash
Password protection, waterproof
TAA Compliant
Software Included
Limited warranty - 5 years
77.9 mm
22 mm
12.05 mm
60 °C
