Kingston 32GB DDR4-2400MHz LRDIMM Dual Rank Module
Quicklinx: C53XWS00 Mfr#: KTD-PE424L/32G
Kingston manufacture the most reliable memory you can buy for a Dell Server. Kingstons legendary reputation is built around reliable memory, that will power your Dell server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this Dell compatible memory module.
Each chip that is built onto the Dell memory board has been scrutnised to the highest level to ensure it meets Kingston's very high quality standards before it enters the manufacturing process. Kingston has developed one of the most advanced testing facilities in the industry for the manufacture of Dell server memory upgrades. Kingston employs a multi-tiered testing system to ensure quality control throughout the design and manufacturing process of all Dell memory upgrades for Server environments.
Kingston - DDR4 - module - 32 GB - LRDIMM 288-pin - 2400 MHz / PC4-19200 - LRDIMM
Memory module
32 GB
Memory Type
DDR4 SDRAM - LRDIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Dual rank, Load-Reduced
Voltage
1.2 V
Lead Plating
Gold
DELL A8711889
Limited lifetime warranty (Russia - 10 years)
Dell Precision Rack 7910; Precision Tower 7910
32 GB
Upgrade Type
System specific
DELL A8711889
DRAM memory module
DDR4 SDRAM
LRDIMM 288-pin
Speed
Latency Timings
CL17
ECC
Module Configuration
4096 x 72
Voltage
1.2 V
Lead Plating
Gold
Dell Precision Rack 7910 , Dell Precision Tower 7910
