Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
- Kingston - DDR4 - module - 32 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
- Product Type
- Memory module
- Capacity
- 32 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Registered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- HP 728629-B21
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- HPE Apollo 4200 Gen9, 4520 Gen9; ProLiant BL660c Gen9, DL120 Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL388 Gen9, DL560 Gen9, DL580, DL580 Gen9, DL80 Gen9, ML110 Gen9, WS460c Gen9, XL170r Gen9, XL190r Gen9, XL230a Gen9, XL250a Gen9, XL450 Gen9, XL740f Gen9, XL750f Gen9; StoreEasy 3850
- Capacity
- 32 GB
- Upgrade Type
- System specific
- HP 728629-B21
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15
- ECC
- Registered
- Module Configuration
- 4096 x 72
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Designed For
- HPE Apollo 4200 Gen9 for Google, 4520 Gen9 , HPE ProLiant BL460c Gen9, BL460c Gen9 Base, BL460c Gen9 Entry, BL460c Gen9 Performance, BL660c Gen9, DL120 Gen9, DL120 Gen9 Entry, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 High Performance, DL360 Gen9 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL380z Gen9, DL388 Gen9, DL388 Gen9 Base, DL560 Gen9, DL560 Gen9 Base, DL560 Gen9 Entry, DL560 Gen9 Performance, DL580 Gen9, DL580 Gen9 Base, DL580 Gen9 Database, DL580 Gen9 High Performance, DL580 Gen9 SAP HANA Scale-out Base Configuration, DL580 Gen9 SAP HANA Scale-up Base Configuration, DL580 Intel E7 8800v4 Scale-out SAP HANA Tailored Datacenter Integration Compute Block, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, WS460c Gen9, WS460c Gen9 Graphics, WS460c Gen9 Graphics Expansion, XL170r Gen9, XL190r Gen9, XL230a Gen9, XL230a Gen9 Compute Tray, XL230a Gen9 Compute Tray (12G), XL230a Gen9 Compute Tray (6G), XL230a Gen9 NHP Compute Tray (12G), XL250a Gen9, XL250a Gen9 Accelerator Tray, XL450 Gen9, XL730f Gen9, XL740f Gen9, XL750f Gen9 , HPE StoreEasy 3850 Gateway Single Node
