Product
Kingston 32GB DDR4-2133MHz Reg ECC Module
Quicklinx: BRPCWS00 Mfr#: KTD-PE421/32G
For over 25 years Kingston have been manufacturing high quality memory and RAM for computer upgrades for desktops, laptops, servers, motherboards and more. The Kingston D4G72M151 32GB DDR4 2133MHz Reg ECC Memory RAM DIMM module is made to the highest possible standard, undergoing rigorous and unrivalled testing to ensure it performs as you would expect it to. Kingston offers lifetime warranrty on all its memory modules to back up its assurance of quality. Kingston is involved in the DRAM process from the dicing of the wafer to encasing the integrated circuits and from assembling the module to testing the finished product meaning Kingston are involved in every part of the manufacturing process to ensure excellent quality control.
Kingston - DDR4 - 32 GB - DIMM 288-pin - registered
RAM memory
32 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Registered
Voltage
1.2 V
Lead Plating
Gold
DELL A8217683
Limited lifetime warranty (Russia - 10 years)
Dell PowerEdge R630, R730, T630; Precision Tower 5810, 7810
32 GB
Upgrade Type
System specific
DELL A8217683
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Registered
Module Configuration
4096 x 72
Voltage
1.2 V
Lead Plating
Gold
Dell PowerEdge R630, R730, T630 , Dell Precision Tower 5810, 7810
