Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
- Kingston - DDR4 - module - 32 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
- Product Type
- Memory module
- Capacity
- 32 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Registered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- Cisco UCS-MR-1X322RU
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- Cisco UCS B200 M4 Entry SmartPlay, B200 M4 Performance Smart Play, B200 M4 Value Smart Play, B420 M4 Blade Server, C220 M4 Entry Plus Smart Play, C220 M4 Entry Smart Play, C220 M4 Rack Server, C220 M4 Value Smart Play, C240 M4 High-Density Rack Server, C240 M4 Rack Server
- Capacity
- 32 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15
- ECC
- Registered
- Module Configuration
- 4096 x 72
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Designed For
- Cisco UCS B200 M4 Entry SmartPlay, B200 M4 Performance Smart Play, B200 M4 Value Smart Play, B420 M4 Blade Server, C220 M4 Entry Plus Smart Play, C220 M4 Entry Smart Play, C220 M4 Rack Server, C220 M4 Value Smart Play, C240 M4 High-Density Rack Server (Small Form Factor Hard Disk Drive Model), C240 M4 Rack Server
