Your basket is empty
Kingston 32GB DDR4-2133MHz LRDIMM Quad Rank Module
Quicklinx: BW0QWS00 Mfr#: KTH-PL421LQ/32G
Kingston - DDR4 - 32 GB - LRDIMM 288-pin - 2133 MHz / PC4-17000 - CL15 - 1.2 V - Load-Reduced - ECC
RAM memory
32 GB
Memory Type
DDR4 SDRAM - LRDIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Quad rank, Load-Reduced
Voltage
1.2 V
Lead Plating
Gold
HP 726722-B21, HP 726722-S21
Limited lifetime warranty (Russia - 10 years)
HPE Apollo 4510 Gen9, 4520 Gen9, 4530; ProLiant BL460c Gen9, BL660c Gen9, DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL388 Gen9, DL560 Gen9, DL580 Gen9, DL80 Gen9, ML350 Gen9, WS460c Gen9, XL170r Gen9, XL190r Gen9, XL230a Gen9, XL250a Gen9
32 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
LRDIMM 288-pin
Speed
Latency Timings
CL15
ECC
Module Configuration
4096 x 72
Voltage
1.2 V
Lead Plating
Gold
HPE Apollo 4510 Gen9, 4520 Gen9, 4530 , HPE ProLiant BL460c Gen9, BL460c Gen9 Base, BL460c Gen9 Entry, BL460c Gen9 Performance, BL660c Gen9, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 Performance, DL388 Gen9, DL388 Gen9 Base, DL560 Gen9, DL560 Gen9 Base, DL560 Gen9 Entry, DL560 Gen9 Performance, DL580 Gen9, DL580 Gen9 Database, DL580 Gen9 SAP HANA Scale-up Base Configuration, DL80 Gen9, DL80 Gen9 Entry, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, WS460c Gen9 Graphics, WS460c Gen9 Graphics Expansion, XL170r Gen9, XL190r Gen9, XL230a Gen9, XL230a Gen9 Compute Tray, XL230a Gen9 Compute Tray (12G), XL230a Gen9 Compute Tray (6G), XL230a Gen9 NHP Compute Tray (12G), XL250a Gen9 Accelerator Tray
