DataTraveler Micro 3.1 is an ultra-small, capless, lightweight flash drive that delivers extreme USB 3.1 speeds of up to 100 MB/s read and 15MB/s write. It's small enough to stay plugged into your notebook when you place it in your bag, and it has a built-in keyhole. Store your favorite music, movies, files and more with this Plug-and-Play drive that's ideal for tablets, notebooks, car stereos and televisions.
Ultra-small
This compact and lightweight drive is easy to take with you and small enough to keep plugged into your notebook even when placed in its bag. -
Metal casing
The drive's metal casing complements any compatible device. It's capless, so there's no cap to lose or break. -
USB 3.1 speeds
With speeds of up to 100 MB/s, DT Micro 3.1 saves time, even with large files, and is faster than USB 2.0 flash drives.
- Kingston DataTraveler Micro 3.1 - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1
- Storage Capacity
- 32 GB
- OS Required
- Linux 2.6.x or later, Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Windows 8.1, Apple MacOS X 10.7.x or later
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- Read Rate
- Up to 100 MB/s
- Write Rate
- Up to 15 MB/s
- Interface Type
- USB 3.1
- Metal body, key ring loop
- Plug and Play
- OS Required
- Limited warranty - 5 years
- 24.95 mm
- 12.2 mm
- 4.5 mm
- 0 °C
- 60 °C
