Kingston 32Gb Canvas Go Class 10 MicroSD UHS-I
Quicklinx: DK4RWS00 Mfr#: SDCG2/32GB
Kingston's Canvas Go! card is designed to be mobile, making it ideal for filming life's adventures. You can be confident that your memories will be safe when documenting the next journey on your drone or dash cam.
  • Made for movement
    Capture your latest hike, underwater adventure, or that sweeping landscape using this card.
  • Get your memories faster
    Transfer and edit your memories quicker thanks to the incredible read speeds.
  • Durable
    For your peace of mind, the card has been extensively tested and proven to be waterproof, temperature proof, shock and vibration proof.
Kingston Canvas Go! - flash memory card - 32 GB - microSDHC UHS-I
Flash memory card
microSDHC UHS-I Memory Card
Storage Capacity
32 GB
Speed Rating
Video Class V30 / UHS-I U3 / Class10
Included Memory Adapter
microSD to SD adapter
Flash memory card
Storage Capacity
32 GB
Speed Class
Read Rate
Up to 90 MB/s
Write Rate
Up to 45 MB/s
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - lifetime
11 mm
15 mm
Thickness
1 mm
-25 °C
85 °C
