Product
Kingston 32GB 2400MHz DDR4 ECC Reg CL17 DIMM (Kit of 4) 1Rx4
Quicklinx: C3B1WS00 Mfr#: KVR24R17S4K4/32
Type: DDR4 SDRAM
Capacity: 32GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: ECC
£311.79 ex VAT
£374.14 inc VAT
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR4 - 32 GB: 4 x 8 GB - DIMM 288-pin - registered with parity
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Temperature monitoring, single rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL17 (17-17-17)
ECC
Module Configuration
1024 X 72
Chips Organization
1024 x 4
Voltage
1.2 V
Lead Plating
Gold
Colour Category
Green
RoHS
Type: DDR4 SDRAM
Capacity: 32GB
Speed: 2400MHz
Data Integrity: ECC
Registered/Buffered: Registered with parity
CAS Latency: CL17
Standard: PC4-19200
Brand: Kingston
Price Range Ex VAT: 300 - 500
