Your basket is empty
Kingston 32GB 2400MHz DDR4 CL14 DIMM (Kit of 2) XMP HyperX Savage Blk
Quicklinx: BSWWWS00 Mfr#: HX424C14SBK2/32
Type: DDR4 SDRAM
Capacity: 32GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: Non-ECC
More than 50 in stock
£184.19 ex VAT
£221.02 inc VAT
Marketing description is not available.
HyperX Savage - DDR4 - 32 GB : 2 x 16 GB - DIMM 288-pin
RAM memory
32 GB : 2 x 16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz ( PC4-19200 )
Latency Timings
CL14 ( 14-14-14 )
Dual rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heat spreader, sixteen banks, asymmetrical heatspreader , unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
32 GB : 2 x 16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.36
Speed
Latency Timings
CL14 ( 14-14-14 )
Non-ECC
Module Configuration
2048 x 64
Chips Organization
1024 x 8
Voltage
1.2 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2400 MHz - 1.2 V - CL14 - 14-14-14
Colour Category
Kingston 32GB 2400MHz DDR4 CL14 DIMM (Kit of 2) XMP HyperX Savage Blk Bundle deal on Kingston 32GB 2400MHz DDR4 CL14 DIMM (Kit of 2) XMP HyperX Savage Blk
£200.51
saving £8.20
Type: DDR4 SDRAM
Capacity: 32GB
Speed: 2400MHz
Registered/Buffered: Unbuffered
CAS Latency: CL14
Standard: PC4-19200
Brand: Kingston
Price Range Ex VAT: 150 - 300
