Your basket is empty
Kingston 32GB 2400MHz DDR3 Non-ECC CL11 DIMM Kit of 4 XMP HyperX Savage
Quicklinx: 9QNFWS00 Mfr#: HX324C11SRK4/32
Type: DDR3 SDRAM
Capacity: 32GB
Connection: DIMM 240-pin
Speed: 2400MHz
Data Integrity: Non-ECC
22 in stock
£246.36 ex VAT
£295.63 inc VAT
Marketing description is not available.
HyperX Savage - DDR3 - 32 GB: 4 x 8 GB - DIMM 240-pin
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC3-19200)
Latency Timings
CL11 (11-13-14)
Dual rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, Black PCB, quad channel, red heat spreader, low profile heat spreader, asymmetrical heatspreader, unbuffered
Voltage
1.65 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.29
Speed
Latency Timings
CL11 (11-13-14)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.65 V
Lead Plating
Gold
Colour Category
Red
Kingston 32GB 2400MHz DDR3 Non-ECC CL11 DIMM Kit of 4 XMP HyperX Savage Bundle deal on Kingston 32GB 2400MHz DDR3 Non-ECC CL11 DIMM Kit of 4 XMP HyperX Savage
£262.68
saving £8.65
Type: DDR3 SDRAM
Capacity: 32GB
Speed: 2400MHz
Registered/Buffered: Unbuffered
CAS Latency: CL11
Standard: PC3-19200
Brand: Kingston
Price Range Ex VAT: 150 - 300
