Product
Kingston 32GB 2133MHz DDR4 ECC Reg CL15 DIMM (Kit of 4)
Quicklinx: BRG5WS00 Mfr#: KVR21R15S4K4/32
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR4 - 32 GB: 4 x 8 GB - DIMM 288-pin - registered with parity
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15 (15-15-15)
Temperature monitoring, single rank, On-Die Termination (ODT), Serial Presence Detect (SPD), Ultra Low Voltage, sixteen banks, registered with parity
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL15 (15-15-15)
ECC
Module Configuration
1024 X 72
Chips Organization
1024 x 4
Voltage
1.2 V
Lead Plating
Gold
RoHS
