Your basket is empty
Kingston 32GB 2133MHz DDR4 CL14 DIMM (Kit of 2) HyperX FURY Black
Quicklinx: C11CWS00 Mfr#: HX421C14FBK2/32
Type: DDR4 SDRAM
Capacity: 32GB
Connection: DIMM 288-pin
Speed: 2133MHz
Data Integrity: Non-ECC
More than 50 in stock
£167.72 ex VAT
£201.26 inc VAT
Engineered and tested to deliver extreme performance, Kingston HyperX easily endures the most rigorous demands of any creative professional, gamer or PC enthusiast.
Kingston HyperX FURY - DDR4 - 32 GB : 2 x 16 GB - DIMM 288-pin
RAM memory
32 GB : 2 x 16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz ( PC4-17000 )
Latency Timings
CL14 ( 14-14-14 )
Dual rank, black heatsink, On-Die Termination (ODT), Serial Presence Detect (SPD), dual channel, Black PCB, low profile heat spreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0) , unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
32 GB : 2 x 16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.34
Speed
Latency Timings
CL14 ( 14-14-14 )
Non-ECC
Module Configuration
2048 x 64
Chips Organization
1024 x 8
Voltage
1.2 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , Intel Extreme Memory Profiles (XMP 2.0) - 2133 MHz - 1.2 V - CL14 - 14-14-14
Colour Category
Kingston 32GB 2133MHz DDR4 CL14 DIMM (Kit of 2) HyperX FURY Black Bundle deal on Kingston 32GB 2133MHz DDR4 CL14 DIMM (Kit of 2) HyperX FURY Black
£184.08
saving £7.75
Type: DDR4 SDRAM
Capacity: 32GB
Speed: 2133MHz
Registered/Buffered: Unbuffered
CAS Latency: CL14
Standard: PC4-17000
Brand: Kingston
Price Range Ex VAT: 150 - 300
