HyperX HX321C11SRK4/32 is a kit of four 1G x 64-bit (8GB) DDR3-2133 CL11 SDRAM (Synchronous DRAM) 2Rx8, memory module, based on sixteen 512M x 8-bit FBGA components per module. Each module kit supports IntelĀ® XMP (Extreme Memory Profiles). Total kit capacity is 32GB. Each module has been tested to run at DDR3-2133 at a low latency timing of 11-12-12 at 1.6V. The SPDs are programmed to JEDEC standard latency DDR3-1600 timing of 11-11-11 at 1.5V. Each 240-pin DIMM uses gold contact fingers.
- HyperX Savage - DDR3 - kit - 32 GB: 4 x 8 GB - DIMM 240-pin - 2133 MHz / PC3-17000 - unbuffered
- Product Type
- Memory kit
- Capacity
- 32 GB: 4 x 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC3-17000)
- Latency Timings
- CL11 (11-12-12)
- Dual rank, eight banks, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, Black PCB, quad channel, red heatspreader, low profile heatspreader, asymmetrical heatspreader, unbuffered
- Voltage
- 1.5 / 1.6 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 32 GB: 4 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.29
- Speed
- Latency Timings
- CL11 (11-12-12)
- Non-ECC
- Module Configuration
- 1024 x 64
- Chips Organization
- 512 x 8
- Voltage
- 1.5 / 1.6 V
- Lead Plating
- Gold
- Colour Category
- Red
