Product
Brand
Kingston 32GB 2133MHz DDR3 Non-ECC CL11 DIMM (Kit of 4) XMP Beast Ser
Quicklinx: 9NGHWS00 Mfr#: HX321C11T3K4/32
Unleash the Beast on your system. The vicious HyperX Beast features a dynamic heatspreader to maximize thermal dissipation for increased reliability. Plus it looks really cool and enhances any system. It's Intel XMP ready so higher-performing frequencies, timings and voltages are just a few clicks away. The Beast gets along well with Intel Core processors and the AMD performance and gaming processors. Put the Beast in your corner and crush your opponents - or just conquer your challenging workload.
HyperX Predator Beast - DDR3 - 32 GB: 4 x 8 GB - DIMM 240-pin
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC3-17000)
Latency Timings
CL11 (11-12-12)
Heat sink, dual rank, eight banks, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, quad channel, unbuffered
Voltage
1.6 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.83
Speed
Latency Timings
CL11 (11-12-12)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.6 V
Lead Plating
Gold
