Product
Brand
Kingston 32GB 1600MHz ECC Kit of 4
Quicklinx: BKJ8WS00 Mfr#: KTH-PL316EK4/32G
Marketing description is not available.
Kingston - DDR3 - 32 GB: 4 x 8 GB - DIMM 240-pin
RAM memory
32 GB: 4 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Unbuffered
HP A2Z50AA (x4)
HP Workstation Z1, Z230, Z420
32 GB: 4 x 8 GB
Upgrade Type
System specific
HP A2Z50AA (x4)
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Unbuffered
Compatible Slots
4 x memory - DIMM 240-pin
