Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
- Kingston - DDR3 - kit - 32 GB: 2 x 16 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - registered
- Product Type
- Memory kit
- Capacity
- 32 GB: 2 x 16 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1866 MHz (PC3-14900)
- Latency Timings
- CL13
- Registered
- Voltage
- 1.5 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- Apple MF622G/A (x2)
- Limited lifetime warranty
- Capacity
- 32 GB: 2 x 16 GB
- Upgrade Type
- System specific
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL13
- ECC
- Registered
- Module Configuration
- 2048 x 72
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Compatible Slots
- 2 x memory - DIMM 240-pin
