Kingston's Data Center DC500M SSDs are designed for read centric and mixed-use server workloads. They implement Kingston's strict QoS requirements to ensure predictable random I/O performance as well as predictable low latencies over a wide range of read and write workloads.
Optimized for mixed-use applications
An exceptional balance of consistent I/O delivery and high read and write IOPS performance to manage a wide range of transactional workloads. -
Reduce application latencies
Data center's hosting databases and various web-based applications can leverage the predictable I/O and latency performance.
- Kingston Data Center DC500M - SSD - 3.84 TB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 3.84 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- 3D triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Dynamic and Static Wear Leveling, Hot-Plug Support, Power Loss Protection (PLP), S.M.A.R.T., 256-bit AES
- 69.9 mm x 100 mm x 7 mm
- 92.34 g
- 5-year warranty
- Capacity
- 3.84 TB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.9 mm
- 100 mm
- 7 mm
- 92.34 g
Performance
- Drive Writes Per Day (DWPD)
- 1.3
- SSD Endurance
- 9110 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 555 MBps (read) / 520 MBps (write)
- 4KB Random Read
- 98000 IOPS
- 4KB Random Write
- 75000 IOPS
Reliability
- MTBF
- 2,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 1.6 watt (average) , 1.56 watt (idle) , 1.8 watt (read) , 7.5 watt (write)
- Limited warranty - 5 years , Technical support
- 0 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
Kingston 3.84TB DC500M 2.5" SATA 6Gb/s SSD
