Your basket is empty
Kingston 2GB 240-PIN DDR2 800MHz CL6
Quicklinx: 5JWSWS00 Mfr#: KVR800D2N6/2G
Type: DDR2 SDRAM
Capacity: 2GB
Connection: DIMM 240-pin
Speed: 800MHz
Registered/Buffered: Unbuffered
47 in stock
£23.90 ex VAT
£28.68 inc VAT
Standard delivery Delivered within 3-5 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR2 - 2 GB - DIMM 240-pin
RAM memory
2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Unbuffered
Voltage
1.8 V
Lead Plating
Gold
Limited lifetime warranty (Germany, Austria and France - 10 years)
AOpen XC Cube EU965, EZ965; Biostar A740G M2+, GF8200 M2+
2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
800 MHz (PC2-6400)
Latency Timings
CL6
Non-ECC
Unbuffered
Module Configuration
256 x 64
Chips Organization
128 x 8
Voltage
1.8 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
AOpen XC Cube EU965, EZ965 , Biostar A740G M2+, GF8200 M2+
Kingston 2GB 240-PIN DDR2 800MHz CL6 Bundle deal on Kingston 2GB 240-PIN DDR2 800MHz CL6
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £5.30 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £1.60 | while stocks last
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £10.63 | in stock
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.43 | in stock
£39.93
saving £6.94
Type: DDR2 SDRAM
Capacity: 2GB
Speed: 800MHz
Brand: Kingston
Price Range Ex VAT: 0 - 50
