Kingston's KC400 SSD is faster than a hard drive to deliver consistent performance for both compressible and incompressible data and improve responsiveness in performance-hungry applications. It uses a powerful processor to speed up daily tasks and improve productivity. KC400 provides end-to-end data path protection and SmartECC to guard data, plus SmartRefresh to protect against read errors. Data is rebuilt if there's an error, and the drive is able to recover from an unexpected power shutdown, thanks to firmware-controlled power loss management. Advances in controller technology and NAND give this drive excellent data reliability.
- Kingston SSDNow KC400 Upgrade Bundle Kit - solid state drive - 256 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 256 GB
- Form Factor
- 2.5" (in 3.5" carrier)
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- TRIM support, Phison PS3110-S10 controller, Advanced Smart ECC, Firmware-based Power-Loss Protection, S.M.A.R.T.
- 69.9 mm x 100.1 mm x 7 mm
- 60 g
- 5-year warranty
- Capacity
- 256 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.9 mm
- 100.1 mm
- 7 mm
- 60 g
Performance
- SSD Endurance
- 800 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 550 MBps (read) / 540 MBps (write)
- 4KB Random Read
- 88000 IOPS
- 4KB Random Write
- 89000 IOPS
- Maximum 4KB Random Write
- 88000 IOPS
- Maximum 4KB Random Read
- 99000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" or 3.5" (with included bay adapter)
- Power Consumption
- 3.74 Watt (active) , 0.255 Watt (idle) , 0.335 Watt (average)
- Software Included
- Drivers & Utilities
- Included Accessories
- 2.5" SATA enclosure, 3.5-inch bay adapter, 2.5mm mounting spacer
- Cables Included
- 1 x USB cable , 1 x Serial ATA power adapter - internal , 1 x Serial ATA cable - internal
- Mounting Kit
- Included
- Limited warranty - 5 years , Technical support
- 0 °C
- 70 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
