Kingston 256GB Canvas Go SDXC Card
Quicklinx: DS7ZWS00 Mfr#: SDG/256GB
Type: SDXC UHS-I Memory Card
Capacity: 256GB
SD Speed Class: Video Class V30 / UHS-I U3 / Class10
£28.07 ex VAT
£33.68 inc VAT
Kingston's Canvas Go! card is designed to be used on the go, making it ideal for filming life's adventures. You can be confident that your memories will be safe when documenting the next journey on your DSLR, drone or action camera.
  • Made for movement
    Capture your latest hike, underwater adventure or that sweeping landscape using this card.
  • Get your memories faster
    Transfer and edit your memories quicker thanks to the incredible read speeds.
Kingston Canvas Go! - flash memory card - 256 GB - SDXC UHS-I
Flash memory card
Storage Capacity
256 GB
Speed Rating
Flash memory card
Storage Capacity
256 GB
Compatibility
Non-specific
SD Speed Class
Read Rate
Up to 90 MB/s
Write Rate
Up to 45 MB/s
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - lifetime
24 mm
32 mm
2.1 mm
-25 °C
85 °C
Capacity: 256GB
Brand: Kingston
Price Range Ex VAT: 0 - 50
