Kingston 256GB A2000 M.2 NVMe PCIe SSD XTS-AES 256-bit
Quicklinx: FBMKWS00 Mfr#: SA2000M8/250G
Form Factor: M.2 2280
Capacity: 250GB
Interface: PCI Express 3.0 x4 (NVMe)
Type: Internal hard drive
19 in stock
£41.09 ex VAT
£49.30 inc VAT
Kingston's A2000 NVMe PCIe SSD is an affordable storage solution with impressive performance. Boasting read/write speeds of up to 2,200/2,000MB/s1, A2000 delivers 3x the performance of a SATA SSD with quicker loading times, less power consumption and lower heat. A2000 SSD is designed for the entry-level user, purpose-built system manufacturer, DIY system builder and those seeking to upgrade their PC. With a single-sided slim M.2 design, A2000 works to its full potential when installed in an Ultrabook or a small-form-factor PC (SFF PC) system.
A2000 is a self-encrypting drive that supports end-to-end data protection using 256-bit XTS-AES hardware-based encryption, and allows the use of independent software vendors with TCG Opal 2.0 security management solutions such as Symantec, McAfee, WinMagic and others. A2000 also has built-in eDrive support, a security storage specification for use with BitLocker.
  • NVMe PCIe performance at a fraction of the cost
    A2000 is an affordable solution with impressive read/write speeds up to 2,200/2,000MB/s.
  • Full-security suite support
    Protect and secure your data with Kingston’s self-encrypting drive.
Kingston A2000 - solid state drive - 250 GB - PCI Express 3.0 x4 (NVMe)
Solid state drive - internal - NVM Express (NVMe)
250 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
M.2 2280
NVM Express (NVMe)
22 mm x 80 mm x 3.5 mm
6.6 g
5-year warranty
250 GB
Hardware Encryption
256-bit AES
M.2 2280
NVM Express (NVMe)
22 mm
80 mm
3.5 mm
6.6 g
Performance
SSD Endurance
150 TB
Internal Data Rate
2200 MBps (read) / 1000 MBps (write)
Maximum 4KB Random Write
240000 IOPS
Maximum 4KB Random Read
220000 IOPS
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe) - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
0.15 Watt (idle) , 0.8 Watt (average) , 0.5 Watt (read) , 1 Watt (write)
ISO 9001, SGS
Limited warranty - 5 years
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 20-1000 Hz
Capacity: 250GB
Brand: Kingston
Price Range Ex VAT: 0 - 50
