Kingston's SSDNow V300 solid-state drive is a cost-effective way to revive your computer. It's 10x faster than a hard drive plus more reliable, more durable and shock-proof. It features an LSI SandForce controller customized for Kingston and best-in-class components, and is available in kits with all the accessories needed for an effortless transition to the latest technology. For added peace of mind, it's backed by a three-year warranty, free technical support and legendary Kingston reliability.
Fast -- 10x faster than a 7200RPM hard drive
High Quality -- features an LSI® SandForce® controller customized for Kingston
Reliable -- with no moving parts, solid-state drives are less likely to fail than standard hard drives
Economical -- design optimized to make migrating to an SSD more affordable
Convenient -- all-in-one kits with all the components for easy installation
Multiple capacities -- to fit your workload
Guaranteed -- three-year warranty, free technical support and legendary Kingston reliability
Compressible Data Transfer (ATTO)
- All capacities: 450MB/s Read and 450MB/s Write
Incompressible Data Transfer (AS-SSD and CrystalDiskMark)
- 60GB -- 150MB/s Read and 50MB/s Write
- 120GB -- 180MB/s Read and 133MB/s Write
- 240GB -- 191MB/s Read and 142MB/s Write
- 480GB -- 450MB/s Read and 208MB/s Write
IOMETER Maximum Random 4k Read/Write
- 60GB -- up to 85,000/ up to 60,000 IOPS
- 120GB -- up to 85,000/ up to 55,000 IOPS
- 240GB -- up to 85,000/ up to 43,000 IOPS
- 480GB -- up to 73,000/ up to 28,000 IOPS
PCMARK® Vantage HDD Suite Score
- 60GB: 39,000
- 120GB: 49,000
- 240GB: 57,000
- 480GB: 57,000
Faster
Applications are loaded in the shortest possible time and the system starts faster. -
Reliable
Solid-state drives have no moving parts and are therefore less prone to failure than conventional hard disks. -
Economical
The optimal concept for affordable migration to an SSD.
- Kingston SSDNow V300 - solid state drive - 240 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 240 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Shock resistant, TRIM support, SandForce Driven, S.M.A.R.T.
- 69.8 mm x 100.1 mm x 7 mm
- 86 g
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Capacity
- 240 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.8 mm
- 100.1 mm
- 7 mm
- 86 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 450 MBps (read) / 450 MBps (write)
- Maximum 4KB Random Write
- 43000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 2.052 Watt (active) , 0.64 Watt (idle)
- Limited warranty - 3 years , Technical support
- 0 °C
- 70 °C
- Vibration Tolerance
- 2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
