Kingston 240GB SSDNow mSATA 6GB/s Solid State Drive
Quicklinx: 9FHCWS00 Mfr#: SMS200S3/240G
Kingston's SSDNow mS200 mSATA solid-state drive oers a cost effective performance boost with a dual-drive option that allows room for adding high-capacity storage. Ideal for system builders, OEMs and enthusiasts, the mS200s ruggedly-cool, miniscule form factor is eight times smaller than a traditional 2.5-inch hard drive, making it perfect for notebooks, tablets and Ultrabooks. Available in capacities of up to 480GB, ms200 has a caseless, PCB-only design with no moving parts and is backed by a three-year warranty (30GB model has a two-year warranty), free technical support and legendary Kingston reliability.
  • mSATA interface - fully compliant with industry standard, easy to fit, guaranteed to work
  • NAND Flash memory based - shock-resistant with low power consumption
  • Supports Intel's SRT - combines capacity advantage of HDD with performance improvements of SSD in dual-storage configuration
  • Supports SMART - monitors the status of your drive
  • Supports TRIM - maintains maximum performance on compatible operating systems
  • Guaranteed - three-year warranty (two-year warranty on 30GB), free technical support
  • SATA interface
    Fully compliant with industry standard, easy to fit, guaranteed to work.
    Shock-resistant with low power consumption.
    Combines capacity advantage of HDD with performance improvements of SSD in dual-storage configuration.
  • Supports SMART
    Monitors the status of your drive.
  • Supports TRIM
    Maintains maximum performance on compatible operating systems.
Kingston SSDNow mS200 - solid state drive - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
mSATA
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, TRIM support, Smart Response Technology, SandForce SF-2241 controller, S.M.A.R.T.
30 mm x 50.88 mm
6.86 g
3-year warranty
240 GB
mSATA
SATA 6Gb/s
30 mm
50.88 mm
6.86 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 530 MBps (write)
4KB Random Read
21000 IOPS
4KB Random Write
41000 IOPS
Maximum 4KB Random Write
40000 IOPS
Maximum 4KB Random Read
72000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 52 pin mini-SATA
Compatible Bay
mSATA
Power Consumption
1.8 Watt (write) , 0.4 Watt (idle) , 1.2 Watt (read)
ISO 9001:2008
Limited warranty - 3 years
70 °C
