HyperX Savage SSD
Powerful performance, unparalleled design.
HyperX® Savage solid-state drive offers extreme performance for the extreme performer. The fastest HyperX SATA-based SSD, it’s powered by a quad-core, 8-channel Phison S10 controller that delivers incredible speeds up to 560MB/s read and 530MB/s write, with read/write IOPS up to 100k/89k. The result is ultra-responsive multitasking and an overall faster system that maintains performance even as the drive fills up.
With its low profile and slim, 7mm form factor, HyperX Savage SSD fits in most notebooks, desktops and HTPC builds. Its unique look, with high-quality red steel and aluminum casing and diamond-cut design, helps you stand out in the crowd and complements the latest PC hardware.
HyperX Savage SSD is 100-percent factory tested and backed by a three-year warranty, free technical support and legendary reliability.
HyperX Savage is ideal for:
• Ultra-responsive multitasking
• An overall faster system
• Quick transfer and edit of large media files
• Power users, content creators and enthusiasts
FEATURES/ BENEFITS
Performance — incredible speeds for enhanced productivity
Unique design — stunning red casing to give an edge to the latest PC hardware
Slim — 7mm thickness to fit in most desktops and notebooks
Guaranteed — three-year warranty and free technical support
- HyperX Savage - SSD - 240 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 240 GB
- Form Factor
- 2.5" (in 3.5" carrier)
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Phison PS3110-S10 controller
- 69.9 mm x 100 mm x 7 mm
- 96 g
- 3-year warranty
- Capacity
- 240 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.9 mm
- 100 mm
- 7 mm
- 96 g
Performance
- Drive Writes Per Day (DWPD)
- 1.19
- SSD Endurance
- 306 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 560 MBps (read) / 530 MBps (write)
- 4KB Random Read
- 93000 IOPS
- 4KB Random Write
- 89000 IOPS
- Maximum 4KB Random Write
- 89000 IOPS
- Maximum 4KB Random Read
- 100000 IOPS
Reliability
- MTBF
- 1,000,000 hour(s)
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5" or 3.5" (with included bay adapter)
- Power Consumption
- 1.4 Watt (read) , 4.35 Watt (write) , 0.39 Watt (idle) , 0.5 Watt (average)
- Included Accessories
- 3.5-inch bay adapter, 7mm to 9.5mm holder
- Mounting Kit
- Included
- ISO 9001:2008, SGS
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
