Kingston 1TB SSDNOW KC400 SATA 6Gb/s 2.5" SSD
Quicklinx: BVQJWS00 Mfr#: SKC400S37/1T
Kingston's KC400 SSD is faster than a hard drive to deliver consistent performance for both compressible and incompressible data and improve responsiveness in performance-hungry applications. It uses a powerful processor to speed up daily tasks and improve productivity. KC400 provides end-to-end data path protection and SmartECC to guard data, plus SmartRefresh to protect against read errors. Data is rebuilt if there's an error, and the drive is able to recover from an unexpected power shutdown, thanks to firmware-controlled power loss management. Advances in controller technology and NAND give this drive excellent data reliability.
  • Notebook and desktop PC use
    Kingston solid-state drives will make your system boot quicker, load applications faster and shut down faster. They are ideal for notebook and desktop use to increase the performance of common office and multimedia applications.
  • Extending the life of older systems
    Kingston SSDs will not only increase performance and make data more secure but they can also be used to extend the life of older systems and enable an organization to delay a PC refresh and potentially save thousands of dollars.
  • Multimedia
    If you work with large images or video files, you know that these files and the applications that use them are very dependent on your drive's storage performance. Whether you are applying layers and effects to an image or editing HD video content, an SSD can deliver more data faster than a traditional hard drive.
Kingston SSDNow KC400 - SSD - 1 TB - SATA 6Gb/s
Solid state drive - internal
1 TB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, Phison PS3110-S10 controller, Advanced Smart ECC, Firmware-based Power-Loss Protection, S.M.A.R.T.
69.9 mm x 100.1 mm x 7 mm
60 g
5-year warranty
1 TB
2.5"
SATA 6Gb/s
69.9 mm
100.1 mm
7 mm
60 g
Performance
SSD Endurance
800 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 530 MBps (write)
4KB Random Read
86000 IOPS
4KB Random Write
89000 IOPS
Maximum 4KB Random Write
89000 IOPS
Maximum 4KB Random Read
99000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
3.74 Watt (active) , 0.255 Watt (idle) , 0.335 Watt (average)
Limited warranty - 5 years , Technical support
70 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
