Your basket is empty
Kingston 1TB SSDNOW KC400 SATA 6Gb/s 2.5" SSD
Quicklinx: BVQJWS00 Mfr#: SKC400S37/1T
Form Factor: 2.5"
Capacity: 1TB, 1TB
Interface: Serial ATA-600
Type: Internal hard drive
Hurry, only 3 left in stock!
£288.97 ex VAT
£346.76 inc VAT
Kingston's KC400 SSD is faster than a hard drive to deliver consistent performance for both compressible and incompressible data and improve responsiveness in performance-hungry applications. It uses a powerful processor to speed up daily tasks and improve productivity. KC400 provides end-to-end data path protection and SmartECC to guard data, plus SmartRefresh to protect against read errors. Data is rebuilt if there's an error, and the drive is able to recover from an unexpected power shutdown, thanks to firmware-controlled power loss management. Advances in controller technology and NAND give this drive excellent data reliability.
Kingston SSDNow KC400 - solid state drive - 1 TB - SATA 6Gb/s
Solid state drive - internal
1 TB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, Phison PS3110-S10 controller, Advanced Smart ECC, Firmware-based Power-Loss Protection, S.M.A.R.T.
69.9 mm x 100.1 mm x 7 mm
60 g
5 years warranty
1 TB
2.5"
SATA 6Gb/s
69.9 mm
100.1 mm
7 mm
60 g
Performance
SSD Endurance
800 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 530 MBps (write)
4KB Random Read
86000 IOPS
4KB Random Write
89000 IOPS
Maximum 4KB Random Write
89000 IOPS
Maximum 4KB Random Read
99000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
3.74 Watt (active) , 0.255 Watt (idle) , 0.335 Watt (average)
Limited warranty - 5 years , Technical support
70 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Kingston 1TB SSDNOW KC400 SATA 6Gb/s 2.5 Bundle deal on Kingston 1TB SSDNOW KC400 SATA 6Gb/s 2.5" SSD
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.43 | in stock
£291.69
saving £2.72
Form Factor: 2.5"
Capacity: 1TB
Capacity: 1TB
Brand: Kingston
Price Range Ex VAT: 150 - 300
