Product
Brand
Kingston 1GB SODIMM Module
Quicklinx: 42TYWS00 Mfr#: KTT667D2/1G
All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for Toshiba Notebook Memory.
Kingston - DDR2 - 1 GB - SO-DIMM 200-pin
RAM memory
1 GB
Memory Type
DDR2 SDRAM - SO-DIMM 200-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
667 MHz (PC2-5300)
Unbuffered
Toshiba PA3512U-1M1G
Limited lifetime warranty (Germany, Austria and France - 10 years)
Toshiba Portégé M400, M700, R500; Qosmio G30, G40; Satego P100, P200, X200; Satellite A200, A210, A300, L300, L300/C02, L300/D02, L300/F00, L40, P100, P200, P200/804, T115, U200, U300, X200; Satellite Pro A120, A200, A210, A300, L300, L40, P100, P200, U300, X200; Tecra A8, A9, M5, M7, M9, M9L, S5
1 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
SO-DIMM 200-pin
Speed
667 MHz (PC2-5300)
Non-ECC
Unbuffered
Compatible Slots
1 x memory - SO-DIMM 200-pin
Toshiba Qosmio G40 , Toshiba Satellite A200-29L, A200-2BL, A200-2C5, A200-2C9, A300-0F7, A300-10M, A300-11X, A300-1DE, A300-1DG, A300-1IH, A300-1IJ, A300-1IK, A300-1IY, A300-1K8, A300-1KM, A300-1MX, A300-1PO, A300-1RH, A300-1RJ, A300-20P, A300-221, A300-22Z, A300-230, A300-237, A300-244, A300-25G, A300-276, A300-27Z, A300-280, A300-29J, A300-29K, A300-29T, A300-29U, A300-2CE, A300-2CF, A300D-167, A300D-18H, A300D-207, A300D-21D, A300D-21J, A300D-21R, A300D-221, A300D-226, A300D-22E, A300-ST3511, L300-0WE04H, L300-13N, L300-145, L300-156, L300-17F, L300-180, L300-18G, L300-19U, L300-1BG, L300-1C1, L300-1CM, L300-1ES, L300-1F9, L300-1FD, L300-1FQ, L300-1G4, L300-214, L300-21C, L300-21H, L300-222, L300-223, L300-226, L300-22V, L300-23D, L300-23F, L300-256, L300-257, L300-26K, L300-278, L300-27U, L300-28R, L300-29R, L300-29T, L300-29U, L300-29V, L300-29W, L300-29X, L300-2C1, L300-2C3, L300-2C4, L300-2C5, L300-2C6, L300-2C7, L300-2CC, L300-2CD, L300-2CE, L300-2CN, L300-2CP, L300-2CQ, L300-2CR, L300-2CW, L300-2CZ, L300-2DR, L300-2EL, L300-2F5, L300D-01Q, L300D-03T, L300D-061, L300D-06T, L300D-12g, L300D-147, L300D-14W, L300D-22P, L300D-22R, L300D-23U, L300D-23Z, L300D-242, L300D-243, L300D-245, L300D-249, L300D-24D, L300D-24N, L300D-24Q, L300D-24U, L300D-250, L300D-251, P200-1ES, T115D-SP2001, T115D-SP2001L, T115D-SP2001M, U300-149, X200-21I , Toshiba Satellite Pro A300-038, A300-1DH, A300-1HF, A300-1IG, A300-1IN, A300-24H, A300-24P, A300-24Q, A300-275, A300-28T, A300-2C8, A300-2CT, A300-2CV, A300-2CW, A300-2CZ, A300-2D3, A300-2E3, L300-16F, L300-172, L300-1EA, L300-22P, L300-22W, L300-24P, L300-26W, L300-296, L300-297, L300-298, L300-299, L300-29C, L300-29F, L300-2CH, L300-2CJ, L300-2E5, L300-2ER, L300-2ET, L300-2F4, L300D-11J, L300D-21R, L300D-233, L300D-236, L300D-23X, L300D-248, L300D-24C, L300D-SP5802, L300D-SP6988A, L300D-SP6988C, L300D-SP6988R, L300-SP5917A, L300-SP6993C, L300-SP6993R , Toshiba Tecra A9-16I, M9-19E
