Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for the following systems:
Apple iMac Intel Core 2 Duo 17-inch (Late 2006);
Apple iMac Intel Core 2 Duo 17-inch CD (Late 2006);
Apple iMac Intel Core 2 Duo 20-inch (Late 2006);
Apple iMac Intel Core 2 Duo 24-inch (Late 2006);
Apple iMac Intel Core Duo 17-inch (Early 2006);
Apple iMac Intel Core Duo 20-inch (Early 2006);
Apple MacBook 13-inch;
Apple MacBook Pro 15.4-inch 1.67GHz;
Apple MacBook Pro 15.4-inch 1.83GHz;
Apple MacBook Pro 15.4-inch 2.0GHz/2.16GHz;
Apple MacBook Pro 15.4-inch 2.16GHz/2.33GHz;
Apple MacBook Pro 17-inch 2.16GHz;
Apple MacBook Pro 17-inch 2.33GHz.
- Kingston - DDR2 - module - 1 GB - SO-DIMM 200-pin - 667 MHz / PC2-5300 - unbuffered
- Product Type
- Memory module
- Capacity
- 1 GB
- Memory Type
- DDR2 SDRAM - SO-DIMM 200-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 667 MHz (PC2-5300)
- Latency Timings
- CL5
- Unbuffered
- Voltage
- 1.8 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- Apple MA346G/A, Apple MA837G/A
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Capacity
- 1 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- SO-DIMM 200-pin
- Speed
- Latency Timings
- CL5
- Non-ECC
- Unbuffered
- Module Configuration
- 128 x 64
- Voltage
- 1.8 V
- Lead Plating
- Gold
- Compatible Slots
- 1 x memory - SO-DIMM 200-pin
Customer reviews
Write a review for the Kingston 1GB Module here!
Upgrade to Macbook 2.16 MHz
Reviewed by Anonymous Review Posted 21/02/2009
upgraded my macbook 2.16MHz with two 1GB modules. A very easy upgrade. Powered up the mac and the next thing you know is everything is working well with 2GB of RAM. Excellent value for money ... I wish I was brave enough to upgrade to 4GB since Kingston say its possible, but no mention on the Apple web site.
- Overall
- Ease of use
- Value for money
Memory upgrade for macbook and
Reviewed by Anonymous Review Posted 27/07/2006
The decription doesn't say but this is for the macbook and macbook pro. I installed it into my macbook (white 1.83 combo drive) and it recognised it straight away and is working well. I bought 2 to make it a matched pair. and the macbook seems to be much faster because of it.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
