Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
- Kingston - DDR2 - module - 1 GB - DIMM 240-pin - 800 MHz / PC2-6400 - unbuffered
- Product Type
- Memory module
- Capacity
- 1 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 800 MHz (PC2-6400)
- Latency Timings
- CL6
- Unbuffered
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- Gateway FX540X, FX540XT, FX540XV; MAXDATA Favorit 4000 I, 4000 IS, 4000 IT BTX
- Capacity
- 1 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL6
- Non-ECC
- Unbuffered
- Module Configuration
- 128 x 64
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Gateway FX540X, FX540XT, FX540XV , MAXDATA Favorit 4000 I, 4000 IS, 4000 IT BTX
