Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
This memory is designed for the following systems:
IBM ThinkCentre A52 8153, 8154, 8166, 8167;
IBM ThinkCentre A52 8155, 8156, 1857;
IBM ThinkCentre A52 8158, 8159, 8160;
IBM ThinkCentre A52 8161, 8162, 8163;
IBM ThinkCentre A52 8164, 8165;
IBM ThinkCentre A52 8168, 8169, 8170;
IBM ThinkCentre M52 8099, 8116, 8215;
IBM ThinkCentre M52 8110, 8111, 8112;
IBM ThinkCentre M52 8113, 8114, 8115;
IBM ThinkCentre M52 8211, 8212, 8213, 8214, 8215;
IBM ThinkCentre M52 9210, 9211.
- Kingston - DDR2 - module - 1 GB - DIMM 240-pin - 667 MHz / PC2-5300 - unbuffered
- Product Type
- Memory module
- Capacity
- 1 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 667 MHz (PC2-5300)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- IBM 30R5126, IBM 73P4984, IBM 40J8870, IBM 41X4256
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Capacity
- 1 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - DIMM 240-pin
