Kingston's DataTraveler Vault Privacy 3.0 (DTVP 3.0) USB flash drive provides affordable business-grade security with 256-bit AES hardware-based encryption using XTS block cipher mode, which offers stronger protection than CBC and ECB modes. It protects 100 percent of data stored and enforces complex password protection with minimum characteristics to prevent unauthorized access. For additional peace of mind, the drive locks down and reformats after 10 intrusion attempts. It also features a read-only access mode to avoid potential malware risks.
Companies can add DTVP 3.0 to their standards list with confidence since its industry-leading NAND and controller design allow for NAND to be interchanged without requalification and certification of security features. Plus they no longer have to compromise transfer speeds for safety, due to DTVP 3.0's SuperSpeed USB 3.0 technology and backwards compatibility with USB 2.0.
Companies can also customize the DTVP 3.0 in a variety of ways to meet specific needs and the most frequently requested internal corporate IT requirements, such as serialization numbering, number of attempted password entries, minimum password length and customized product identifier (PID) for standard end-point management software (white-listing).
- Kingston DataTraveler Vault Privacy 3.0 Management-Ready - USB flash drive - 16 GB - TAA Compliant
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 16 GB
- Hardware Encryption
- Encryption Algorithm
- FIPS 197, 256-bit AES-XTS
- OS Required
- Linux 2.6.x or later, Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Windows 8 / 8.1 / 10, Apple MacOS X 10.7 - 10.11.x
- TAA Compliant
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 16 GB
- Read Rate
- Up to 165 MB/s
- Write Rate
- Up to 22 MB/s
- Interface Type
- USB 3.0
- Waterproof, key ring loop, remote management, protective cap
- TAA Compliant
- OS Required
- Limited warranty - 5 years
- 77.9 mm
- 22.2 mm
- 12.05 mm
- 0 °C
- 60 °C
