Kingston 16GB IronKey S1000 Basic FIPS USB 3.0
Quicklinx: BZSXWS00 Mfr#: IKS1000B/16GB
Capacity: 16GB
Interface: USB 3.0
£243.51 ex VAT
£292.21 inc VAT
Deploy mobile workers with confidence
Protecting the sensitive data that employees and contractors work with has evolved from an IT best practice to a business imperative. And once workers go mobile - whether they're working from home, field offices, or while traveling - it becomes even more difficult to keep data secure. That's the IronKey Basic S1000 USB 3.0 hardware-encrypted flash drives. They give your mobile workforce a convenient, high-performing portable storage solution with room for even the largest data sets. And they give you the peace of mind that comes from knowing your data is safe.
Don't let large data files slow you down
Larger data sets mean longer wait times for mobile workers trying to stay productive while on the road. Now with IronKey Basic S1000 USB 3.0 drives, they can stop waiting and start working. This USB 3.0 SuperSpeed drive delivers blazing read performance of up to 400 MB/sec. That's 2x faster than competing USB 3.0 drives and up to 10x faster than USB 2.0 drives.
Enhanced encryption - global compliance
It's tough enough keeping up with data security regulations here in the US - from HIPAA and HITECH to GLBA - but the picture becomes even more complicated internationally. IronKey Basic S1000 helps you nail down this often moving target with a solution that's FIPS 140-2 Level 3 certified. Even better, all IronKey Basic S1000 drives feature hardware-based XTS-AES 256-bit hardware encryption, which provides more protection than CBC and other block cipher modes. And because many regulations are being updated to require this enhanced encryption, IronKey Basic S1000 drives help you future-proof your compliance efforts.
Work with larger data sets
More organizations are making constant use of big data - database files, media content, large documents and more - and that means more storage room. With IronKey Basic S1000 drives, you can store many files and documents.
Rely on IronKey's persistent protection
The IronKey Cryptochip, a proven hardware-based solution, persistently protects your critical data by keeping encryption key management on the device, where it's safe and protected.
Deploy a truly ruggedized solution
IronKey's sleek, anodized aluminum enclosure is built to meet the most stringent standards for military-grade strength and durability. In fact, IronKey Basic S1000 flash drives automatically detect and respond to physical tampering.
  • Deploy mobile workers with confidence
    Protecting the sensitive data that employees and contractors work with has evolved from an IT best practice to a business imperative. And once workers go mobile - whether they're working from home, field offices, or while traveling - it becomes even more difficult to keep data secure. That's why they developed IronKey Basic S1000 USB 3.0 hardware-encrypted flash drives. They give your mobile workforce a convenient, high-performing portable storage solution with room for even the largest data sets. And they give you the peace of mind that comes from knowing your data is safe.
  • Don't let large data files slow you down
    Larger data sets mean longer wait times for mobile workers trying to stay productive while on the road. Now with IronKey Basic S1000 USB 3.0 drives, they can stop waiting and start working. This USB 3.0 SuperSpeed drive delivers blazing read performance of up to 400 MB/sec. That's 2x faster than competing USB 3.0 drives and up to 10x faster than USB 2.0 drives (utilizing a PC, laptop or tablet with a USB 3.0 port).
  • Enhanced encryption = global compliance
  • Rely on ironkey's persistent protection
  • Deploy a truly ruggedized solution
IronKey Basic S1000 - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
16 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, 256-bit AES-XTS
MLC NAND Flash
Linux 2.6.x or later, Microsoft Windows 7 SP1, Windows 8, Windows 8.1 / 10, Apple MacOS X 10.9.x - 10.12.x
5-year warranty
USB flash drive
Storage Capacity
16 GB
Hardware Encryption
Compatibility
Non-specific
Read Rate
Up to 250 MB/s
Write Rate
Up to 100 MB/s
Interface Type
USB 3.0
MLC NAND Flash
Password protection, shockproof, waterproof, tamper-proof, ruggedized, Cryptochip, dust-resistant
TAA Compliant
Limited warranty - 5 years
82.3 mm
21.1 mm
9.1 mm
70 °C
Capacity: 16GB
Interface: USB 3.0
Brand: Kingston
Price Range Ex VAT: 150 - 300
