Product
Brand
Kingston 16GB Dual Rank Kit
Quicklinx: 6DJ3WS00 Mfr#: KTH-XW9400K2/16G
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR2 - 16 GB: 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
667 MHz (PC2-5300)
Dual rank, registered
HP EV285AA (x2), HP 408855-B21
Limited lifetime warranty (Germany, Austria and France - 10 years)
HP Workstation xw9400; HPE ProLiant BL25p G2, BL260c G5, BL45p G2, BL465c, BL465c G5, BL685c, DL145 G3, DL165 G5, DL185 G5, DL365, DL365 G5, DL385 G2, DL385 G5, DL585 G2, DL585 G5, DL785 G5
16 GB: 2 x 8 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
667 MHz (PC2-5300)
ECC
Compatible Slots
2 x memory - DIMM 240-pin
HP Workstation xw9400 , HPE ProLiant BL25p G2, BL260c G5, BL45p G2, BL465c, BL465c G5, BL685c, DL145 G3, DL165 G5, DL165 G5 Special Server, DL185 G5, DL185 G5 Special Server, DL365, DL365 Base, DL365 Entry, DL365 G5, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL385 G2, DL385 G2 Base, DL385 G2 Entry, DL385 G2 High Performance, DL385 G5, DL385 G5 Base, DL385 G5 Entry, DL385 G5 Performance, DL585 G2, DL585 G5, DL785 G5
