Kingston 16GB DDR4 2666 MHz SODIMM Non-ECC CL19 Memory
Quicklinx: DL33WS00 Mfr#: KCP426SD8/16
Kingston DDR4 16 GB SO-DIMM 260-pin 2666 MHz / PC4-21300 CL17 1.2 V unbuffered non-ECC
Kingston - DDR4 - module - 16 GB - SO-DIMM 260-pin / PC4-21300 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MT/s (PC4-21300)
Latency Timings
CL19
Dual rank, unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL19
Non-ECC
Module Configuration
2048 x 64
Chips Organization
X8
Voltage
1.2 V
Lead Plating
Gold
