Kingston - DDR4 - 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - CL17 - 1.2 V - registered - ECC
- Kingston - DDR4 - module - 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - registered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 2400 MHz (PC4-19200)
- Latency Timings
- CL17
- Single rank, registered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 16 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL17
- ECC
- Module Configuration
- 2048 x 72
- Voltage
- 1.2 V
- Lead Plating
- Gold
