Product
Kingston 16GB DDR4-2400MHz Reg ECC Module Single Rank
Quicklinx: CFSKWS00 Mfr#: KCP424RS4/16
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: ECC
£153.89 ex VAT
£184.66 inc VAT
Kingston - DDR4 - 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - CL17 - 1.2 V - registered - ECC
Kingston - DDR4 - 16 GB - DIMM 288-pin - registered
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Single rank, registered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Module Configuration
2048 x 72
Voltage
1.2 V
Lead Plating
Gold
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 2400MHz
Data Integrity: ECC
Registered/Buffered: Registered
CAS Latency: CL17
Standard: PC4-19200
Brand: Kingston
Price Range Ex VAT: 150 - 300
