Product
Kingston 16GB DDR4-2400MHz Reg ECC Module
Quicklinx: C546WS00 Mfr#: KTL-TS424/16G
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: ECC
£148.69 ex VAT
£178.42 inc VAT
Kingston manufacture the most reliable memory you can buy for a Lenovo Server. Kingstons legendary reputation is built around reliable memory, that will power your Lenovo server with ease, whether it be for minimal day hours or an enviroment that requires 24/7 uptime all year round. Kingston's legendary reputation is also reflected with the peace of mind of a full lifetime warranty on this Lenovo compatible memory module.
Each chip that is built onto the Lenovo memory board has been scrutnised to the highest level to ensure it meets Kingston's very high quality standards before it enters the manufacturing process. Kingston has developed one of the most advanced testing facilities in the industry for the manufacture of Lenovo server memory upgrades. Kingston employs a multi-tiered testing system to ensure quality control throughout the design and manufacturing process of all Lenovo memory upgrades for Server environments.
Kingston - DDR4 - 16 GB - DIMM 288-pin - registered
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Registered
Voltage
1.2 V
Lead Plating
Gold
Lenovo 46W0829
Limited lifetime warranty (Russia - 10 years)
Lenovo Flex System x240 M5 9532; Storage DX8200C 5120; System x3650 M5 8871
16 GB
Upgrade Type
System specific
Lenovo 46W0829
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Registered
Module Configuration
2048 x 72
Voltage
1.2 V
Lead Plating
Gold
Lenovo Flex System x240 M5 9532 , Lenovo Storage DX8200C 5120 , Lenovo System x3650 M5 8871
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 2400MHz
Data Integrity: ECC
Registered/Buffered: Registered
CAS Latency: CL17
Standard: PC4-19200
Brand: Kingston
Price Range Ex VAT: 100 - 150
