Kingston DDR4 8 GB DIMM 288-pin 2133 MHz / PC4-17000 CL15 1.2 V registered ECC for Lenovo ThinkServer RD350; RD450; RD550; RD650; TD350
- Kingston - DDR4 - module - 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
- Product Type
- Memory module
- Capacity
- 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Registered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- Lenovo 4X70F28589
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- Lenovo ThinkServer RD350 70D6, 70D7, 70D8, 70D9, 70QK, 70QM; RD450 70DA, 70DB, 70DC, 70DD, 70DE, 70DV, 70DW; RD550 70CV, 70CW, 70CX, 70CY; RD650 70D0, 70D1, 70D2, 70D3, 70D4, 70D5, 70DR, 70DS, 70DT, 70DU; TD350 70DG, 70DH, 70DJ, 70DK, 70DL, 70DM, 70DN, 70DQ
- Capacity
- 8 GB
- Upgrade Type
- System specific
- Lenovo 4X70F28589
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15
- ECC
- Registered
- Module Configuration
- 1024 X 72
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Designed For
- Lenovo ThinkServer RD350 70D6, 70D7, 70D8, 70D9, 70QK, 70QM , Lenovo ThinkServer RD450 70DA, 70DB, 70DC, 70DD, 70DE, 70DV, 70DW , Lenovo ThinkServer RD550 70CV, 70CW, 70CX, 70CY , Lenovo ThinkServer RD650 70D0, 70D1, 70D2, 70D3, 70D4, 70D5, 70DR, 70DS, 70DT, 70DU , Lenovo ThinkServer TD350 70DG, 70DH, 70DJ, 70DK, 70DL, 70DM, 70DN, 70DQ
