Your basket is empty
Kingston 16GB DDR4 2133MHZ REG ECC CL 1
Quicklinx: BRG0WS00 Mfr#: KVR21R15D4/16
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 2133MHz
Data Integrity: ECC
More than 50 in stock
£137.92 ex VAT
£165.50 inc VAT
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR4 - 16 GB - DIMM 288-pin
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15 (15-15-15)
Temperature monitoring, dual rank, On-Die Termination (ODT), Serial Presence Detect (SPD), Ultra Low Voltage, sixteen banks, registered with parity
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL15 (15-15-15)
ECC
Module Configuration
2048 x 72
Chips Organization
1024 x 4
Voltage
1.2 V
Lead Plating
Gold
RoHS
Kingston 16GB DDR4 2133MHZ REG ECC CL 1 Bundle deal on Kingston 16GB DDR4 2133MHZ REG ECC CL 1
£153.93
saving £6.92
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 2133MHz
Data Integrity: ECC
Registered/Buffered: Registered with parity
CAS Latency: CL15
Standard: PC4-17000
Brand: Kingston
Price Range Ex VAT: 100 - 150
