Kingston 16GB DDR3 1866MHz CL13 DIMM Memory
Quicklinx: CMWLWS00 Mfr#: KCS-B200C/16G
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3 - module - 16 GB - DIMM 240-pin - 1866 MHz / PC3-14900 - registered
Memory module
16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL13
Registered
Voltage
1.5 V
Lead Plating
Gold
Cisco UCS-MR-1X162RZ-A
UCS C220 M3, C240 M3
16 GB
Upgrade Type
System specific
DRAM memory module
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL13
ECC
Registered
Module Configuration
2048 x 72
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Cisco MXA UCS C220 M3 Rack Server for Cisco Show and Share Enterprise, C220 M3 Rack Server for Cisco Show and Share Workgroup , Cisco UCS B200 M3 Blade Server, B420 M3 Blade Server, B420 M3 Blade Server (Not a standalone SKU), B420 M3 Value SmartPlay Expansion Pack, B420 M3 Value SmartPlay Solution, C220 M3 Entry 1 Rack Server, C220 M3 Entry 2 Rack Server, C220 M3 Entry Smart Play, C220 M3 High-Density Rack Server Large Form Factor Hard Disk Drive, C220 M3 High-Density Rack-Mount Server Small Form Factor, C220 M3 High-Density Rack-Mount Server Small Form Factor (Not a standalone SKU), C220 M3 Perform 1 Rack Server, C220 M3 Perform 2 Rack Server, C220 M3 Performance Smart Play, C220 M3 Scale Smart Play, C220 M3 Small Form Factor, C220 M3 Small Form Factor Business Edition, C220 M3 Value 1 Rack Server, C220 M3 Value 2 Rack Server, C220 M3 Value Smart Play, C240 M3 Entry 1 Rack Server, C240 M3 Entry 2 Rack Server, C240 M3 Entry SmartPlay, C240 M3 High-Density Rack Server (Large Form Factor Hard Disk Drive Model), C240 M3 High-Density Rack-Mount Server Small Form Factor, C240 M3 Perform 1 Rack Server, C240 M3 Perform 2 Rack Server, C240 M3 Performance Smart Play, C240 M3 Scale Smart Play, C240 M3 Value 1 Rack Server, C240 M3 Value 2 Rack Server, C240 M3 Value Smart Play, Managed C240 M3 High-Density Rack-Mount Server Small Form Factor, Smart Play 8 B420 M3 Value Expansion Pack, SmartPlay Select C3260 Basic, SmartPlay Select C3260 Basic Plus, SmartPlay Select C3260 Entry, SmartPlay Select C3260 Entry Plus, SmartPlay Select C3260 Performance, SmartPlay Select C3260 Performance Plus, SmartPlay Select C3260 Seed, SmartPlay Select C3260 Value
