Your basket is empty
Kingston 16GB DDR3-1600MHZ ECC Module
Quicklinx: 8XMSWS00 Mfr#: KTD-PE316/16G
Kingston memory is designed, manufactured and rigorously tested to meet the exact specifications of each brand name system.
Kingston - DDR3 - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Registered
Voltage
1.5 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
Dell PowerEdge C6100, C6220, C8220, C8220X, M420, M520, M610, M610x, M620, M820, R320, R410, R420, R510, R520, R610, R620, R710, R715, R720, R720xd, R815, R820, T320, T410, T420, T610, T620; PowerVault DL4000, NX3200, NX400; Precision T5500, T7610; Precision Fixed Workstation R5500, R7610, T7600
16 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Registered
Module Configuration
2048 x 72
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Dell PowerEdge C6100, C6220, C6220 II, C8220, C8220X, M420, M520, M610, M610x, M620, M820, R320, R410, R420, R510, R520, R610, R620, R710, R715, R720, R720xd, R815, R820, T320, T410, T420, T610, T620 , Dell PowerVault DL4000, NX3200, NX400 , Dell Precision T5500, T7610 , Dell Precision Fixed Workstation R5500, R7610, T7600, T7600 Advanced, T7600 Base, T7600 Essential
