Kingston 16GB DDR3 1600MHz CL11 DIMM Memory
Quicklinx: CQ1WWS00 Mfr#: KCP3L16RD4/16
Kingston - DDR3L - 16 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - CL11 - 1.35 V - registered - ECC
Kingston - DDR3L - module - 16 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - registered
Memory module
16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11
Dual rank, Low Voltage, registered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
Generic
DRAM memory module
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
2048 x 72
Chips Organization
X4
Voltage
1.35 V
Lead Plating
Gold
