Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products at an attractive price. Kingston ValueRAM is your best source for industry-standard memory to maximise the performance and productivity of your system. Built with A-grade components only, Kingston ValueRAM memory modules come with a lifetime warranty.
- Kingston - DDR3L - module - 16 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - registered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR3L SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1333 MHz (PC3-10600)
- Quad rank, Low Voltage, registered
- Limited lifetime warranty
- Designed For
- HPE Integrity rx2800 i2; ProLiant BL420c Gen8, BL460c G7, BL490c G7, BL620C G7, BL680c G7, DL1000, DL165 G7, DL170E G6, DL360 G7, DL360e Gen8, DL370 G6, DL380 G6, DL380 G7, DL380e Gen8, DL980 G7, ML350e Gen8, ML370 G6, SL160s G6, SL165s G7, SL170s G6, SL335s G7, SL390s G7, SL4540 Gen8, WS460c G6
- Capacity
- 16 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Chips Organization
- X8
- Designed For
- HPE Integrity rx2800 i2 , HPE ProLiant BL420c Gen8, BL620C G7, BL680c G7, DL1000 Multi Node Server, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL170E G6, DL360 G7 Central Management Server, DL360 G7 Special Server, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL370 G6 Special Server, DL380 G6, DL380 G6 Special Rack Server, DL380 G7 Special Server, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, ML350e Gen8 v2 Entry, ML370 G6 Special Server, SL160s G6, SL160s G6 Base, SL160s G6 Entry, SL160s G6 Performance, SL165s G7 Base, SL165s G7 Entry, SL165s G7 Performance, SL170s G6 1U Right Half Width tray, SL170s G6 Base Left Half Width tray, SL335s G7 1U Left Tray Node Server, SL335s G7 1U Right Tray Node Server, SL390s G7 1U Left Tray Node Server, SL390s G7 1U Right Tray Node Server, SL390s G7 2U Left Half Tray Node Server, SL390s G7 4U Left Half Width tray, SL390s G7 4U Left Tray Node Server, SL390s G7 4U Right Half Width tray, SL390s G7 4U Right Tray Node Server, SL390s G7 Base 1U left Half Width tray, SL390s G7 Base 1U Right Half Width tray, SL390s G7 Base 2U Right Half Width tray, SL390s G7 Base 4U Left Half Width tray, SL390s G7 Base 4U Right Half Width tray, SL390s G7 Entry 1U Left Half Width tray, SL390s G7 Entry 1U Right Half Width tray, SL390s G7 Entry 2U Left Half Width tray, SL390s G7 Entry 2U Right Half Width tray, SL390s G7 Performance 1U left Half Width tray, SL390s G7 Performance 2U Left Half Width tray, SL390s G7 Performance 4U Left Half Width tray, SL390s G7 Performance 4U Right Half Width tray, SL4540 Gen8, SL4540 Gen8 Tray 1x Node Server, SL4540 Gen8 Tray 2x Node Server, SL4540 Gen8 Tray 3x Node Server, WS460c G6 Graphics Expansion, WS460c G6 Workstation
