Kingston 16GB DataTraveler 50 USB 3.1 Flash Drive Green
Quicklinx: C9LPWS00 Mfr#: DT50/16GB
Compact, capless storage in a metal case.
DataTraveler® 50 is a lightweight USB Flash drive available in capacities from 8GB to 128GB. The drive’s compact, capless design features a metal casing that complements any compatible device and colorful accents that range by drive capacity. Fast USB 3.1 Gen 1 (USB 3.0) performance ensures data transfer of music, video and more is quick and easy. Backward compatible with existing USB 2.0 ports for convenience. DT 50 is backed by a five-year warranty, free technical support and legendary Kingston® reliability.
  • Compact, lightweight, capless design
  • Metal casing with colorful accent by capacity
  • Fast USB 3.1 Gen 1 (USB 3.0) performance
Kingston DataTraveler 50 - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 3.1
Storage Capacity
16 GB
Enclosure Colour
Green
Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Apple MacOS X 10.8 or later, Windows 8.1, Windows 10
5-year warranty
USB flash drive
Storage Capacity
16 GB
Enclosure Colour
Green
Read Rate
Up to 30 MB/s
Write Rate
Up to 5 MB/s
Interface Type
USB 3.1
Metal body
Limited warranty - 5 years , Technical support
44.9 mm
20 mm
9.2 mm
60 °C
