HyperX® Predator DDR4 memory has a fierce new heat spreader design in black aluminium for greater heat dissipation to optimise reliability. The heat spreader and PCB complement the look and design of the latest PC hardware, so you can dominate in HyperX style.
Predator DDR4 delivers blazing fast speeds of up to 3333 MHz matched with low CL15–CL16 latencies for extreme DDR4 performance, ultraresponsive multitasking and an overall faster system. It complements Intel’s 6 and 8 core processors for faster video editing, 3D rendering and AI processing – and to keep you in the lead while gaming. It’s available in 4GB–16GB modules and in dual and quad channel kits of 8GB–64GB; the kits are rigorously tested for guaranteed compatibility and performance.
Predator DDR4’s Intel XMP-ready profiles are optimised for Intel’s 100 Series chipset, X99 motherboards and Intel Core i7 HEDT processors to ensure compatibility and the highest performance. XMP profiles are hand-tuned so end users can easily overclock their platforms for higherperforming frequencies and lower timings simply by selecting a profile, with no need for manual timing adjustments in BIOS.
HyperX Predator DDR4 keeps its cool even in a deathmatch and takes full advantage of the power efficiency brought by DDR4 for lower power consumption over DDR3. Less power draw results in less heat and higher reliability. HyperX Predator DDR4 is 100 per cent factory tested at speed and backed by free technical support and legendary reliability.
- HyperX Predator - DDR4 - kit - 16 GB: 2 x 8 GB - DIMM 288-pin - 3333 MHz / PC4-26600 - unbuffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 2 x 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 3333 MHz (PC4-26600)
- Latency Timings
- CL16 (16-18-18)
- Single rank, aluminium heat spreader, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
- Voltage
- 1.35 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 16 GB: 2 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Module Height (inch)
- 1.661
- Speed
- Latency Timings
- CL16 (16-18-18)
- Non-ECC
- Module Configuration
- 1024 x 64
- Chips Organization
- 1024 x 8
- Voltage
- 1.35 V
- Lead Plating
- Gold
- RAM Performance
- SPD - 2400 MHz - 1.2 V - CL17 - 17-17-17 , Intel Extreme Memory Profiles (XMP) - 3000 MHz - 1.35 V - CL15 - 15-17-17 , Intel Extreme Memory Profiles (XMP) - 3333 MHz - 1.35 V - CL16 - 16-18-18
- Colour Category
- Black
