Your basket is empty
Kingston 16GB 3000MHz DDR4 CL15 DIMM (Kit of 2) XMP HyperX Predator
Quicklinx: C594WS00 Mfr#: HX430C15PB3K2/16
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 3000MHz
Data Integrity: Non-ECC
More than 50 in stock
£114.28 ex VAT
£137.13 inc VAT
HyperX® Predator DDR4 memory has a fierce new heat spreader design in black aluminium for greater heat dissipation to optimise reliability. The heat spreader and PCB complement the look and design of the latest PC hardware, so you can dominate in HyperX style.
Predator DDR4 delivers blazing fast speeds of up to 3333 MHz matched with low CL15–CL16 latencies for extreme DDR4 performance, ultraresponsive multitasking and an overall faster system. It complements Intel’s 6 and 8 core processors for faster video editing, 3D rendering and AI processing – and to keep you in the lead while gaming. It’s available in 4GB–16GB modules and in dual and quad channel kits of 8GB–64GB; the kits are rigorously tested for guaranteed compatibility and performance.
Predator DDR4’s Intel XMP-ready profiles are optimised for Intel’s 100 Series chipset, X99 motherboards and Intel Core i7 HEDT processors to ensure compatibility and the highest performance. XMP profiles are hand-tuned so end users can easily overclock their platforms for higherperforming frequencies and lower timings simply by selecting a profile, with no need for manual timing adjustments in BIOS.
HyperX Predator DDR4 keeps its cool even in a deathmatch and takes full advantage of the power efficiency brought by DDR4 for lower power consumption over DDR3. Less power draw results in less heat and higher reliability. HyperX Predator DDR4 is 100 per cent factory tested at speed and backed by free technical support and legendary reliability.
Kingston HyperX Predator - DDR4 - 16 GB : 2 x 8 GB - DIMM 288-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3000 MHz ( PC4-24000 )
Latency Timings
CL15 ( 15-17-17 )
Single rank, aluminium heat spreader, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, Intel Extreme Memory Profiles (XMP 2.0) , unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.661
Speed
Latency Timings
CL15 ( 15-17-17 )
Non-ECC
Module Configuration
1024 x 64
Chips Organization
1024 x 8
Voltage
1.35 V
Lead Plating
Gold
RAM Performance
SPD - 2400 MHz - 1.2 V - CL17 - 17-17-17 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.35 V - CL15 - 15-17-17 , Intel Extreme Memory Profiles (XMP) - 3000 MHz - 1.35 V - CL15 - 15-17-17
Colour Category
Kingston 16GB 3000MHz DDR4 CL15 DIMM (Kit of 2) XMP HyperX Predator Bundle deal on Kingston 16GB 3000MHz DDR4 CL15 DIMM (Kit of 2) XMP HyperX Predator
£130.60
saving £7.64
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 3000MHz
Registered/Buffered: Unbuffered
CAS Latency: CL15
Standard: PC4-24000
Brand: Kingston
Price Range Ex VAT: 100 - 150
