Kingston 16GB 2400MHz DDR4 ECC Reg CL17 DIMM 2Rx8 Intel
Quicklinx: CFQVWS00 Mfr#: KVR24R17D8/16I
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR4 - module - 16 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - registered with parity
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Temperature monitoring, dual rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity
Voltage
1.2 V
Lead Plating
Gold
Pricing Type
Intel Memory Validation Program
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL17 (17-17-17)
ECC
Module Configuration
2048 x 72
Chips Organization
1024 x 8
Voltage
1.2 V
Lead Plating
Gold
RoHS
Pricing Type
